path1's avatar
path1
Suburban gas furnace question
I have "install directions" and "user information manual" for what came with RV. Model (take your pick of which one?) sf-20fq, sf-25fq, sf-30fq, sf35fq and sf-42fq. Here is where I'm at and problem(s)
1. (has plenty of propane coming out of stove and have good elec, currently plugged in at home.)
Turn up t-stat and heater comes on for about 8 min then shuts off. I check fuses, all OK...so I dig deeper
2. Remove cover (vent to inside) and see nothing but the metal box, no model numbers and no access without removing (on the left) the inverter and on the right, cabinet structure for kitchen drawers.
3. So before I start taking things apart, I get on-line to find shop manual and can't find anything, like a technician would use.
RV is almost 5 years old, so I want to find and go thru the trouble shooting check list. (I hope all it needs is a good cleaning and I would like to see what the flame looks like.)
Anybody have any links to this model? Any help appreciated.
  • If its burning for about 8 minutes, that to means one of two things. Hi limit switch failure, or thermalcouple failure.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
