Rock2's avatar
Rock2
Suburban Gas valve - test OHM
I need your help. The gas valve number is 25M16V Type 780. (part number 161109) I ordered from Ebay. The package arrived last Saturday. Anyway I want to test coil to make sure they are working before I replace the old gas valve. I tested terminal number 1 and 2 reads 42 ohms. This tell me it is working. Now next test terminal number 3 and 4 read none? My old gas valve has the same reading. If this is what it should, mean it is possible other problem - like maybe bad circuit card? Any advise would be greatly appreciated. Hope to get parts ready to get it fix before gone camping this weekend.
  • Anyway, Two weeks ago, I cleaned burner tube with flexible brush, blow orifice (maybe need to soak with alcohol). Still no flame but spark. After 3rd time, shut down. I could feel gas valve "knock sound"
    Do you think it is possible has to do with auto changeable regulator near by propane bottles?
  • dougrainer wrote:
    Why not just put 12 volts to the 1 and 4 and ground to 2 and 3. Then gently blow thru the inlet and see if air comes out the outlet???????? FYI, I have NEVER seen a gas valve coil really fail on a Suburban in years. Doug
    Thank you Doug! This am I tested the spare gas valve which I bought and sure enuf air blow went thru. I am going to take the circuit card to RV dealer and have them test it. I did not test gas valve on my camper because it is at campground. Will check tmw.
  • Take the coil with resistance off the one they sent you and just replace your open one with it, easy. Then once you get the new one you will have a spare. Bet ya it is the inside one, the one closes to the tank that opened. Put a shield from a flatten pop can or something back there to act as a heat reflector.
  • Why not just put 12 volts to the 1 and 4 and ground to 2 and 3. Then gently blow thru the inlet and see if air comes out the outlet???????? FYI, I have NEVER seen a gas valve coil really fail on a Suburban in years. Doug
  • midnightsadie wrote:
    what is the problem? most times its some thing very simple that shuts things down.
    I contacted the seller. He said both coils should show OHMS. So he is going to send me other gas valve. Hope this will solve the problem. Cross my fingers!
  • what is the problem? most times its some thing very simple that shuts things down.
