tsduke03's avatar
tsduke03
Suburban gas water heater failure to ignite
My water heater doesn't want to light all the time. It will try a few times to ignite and go into lockout. Sometimes it will work fine for a day then fail to ignite again. It's seems like the longer it sits the lest likely to like.
Now, I can pop my grill lighter in there when it's trying to light it will ignite every time.
Igniter maybe?
Thanks!
  • X2 what previous poster said. Also make sure there isn't a single cobweb or obstacle in the burner tube. You would be surprised how much the tiniest cobweb can disrupt the air/gas mixture.
  • The spark electrode is attempting to light main flame..but only does so intermittently. YOU can light main flame with a BBQ lighter so problem is with spark electrode.
    Need to clean spark electrode (emery cloth), set spark gap to 1/8", clean up ground (screw holds bracket provide grd. source), check the ceramic & high tension wire for cracks (also wipe them down with a rag with silicone on it) and then position spark electrode so that it is engulfed by main flame.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
