DutchmenSport
Jun 20, 2016Explorer
I've never actually compared them, but I feel pretty certain the pressure relief valve is threaded the same. Check the valves though, I do think they come in different temperature settings, at least, they use to.
If you have a single valve water heater by-pass on your water heater, then yes, you do have a check valve on the hot out side.
If you have a 2 valve water heater by-pass, you might have a check valve on the hot out side.
If you have a 3 valve water heater by-pass, you probably do not have any check valves.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
