Tlpeacock's avatar
Tlpeacock
Suburban hot water heater
I'm trying to connect the wiring for my hot water heater(suburban sw6d). I have a blue wire, white wire and a yellow wire coming from the junction box. They need to be connected to the on/off switch. And the light reset switch. The problem is this. Also needed to be connected to these two switches. Are two white and two brown wires coming from the system monitor. I am confused as to what goes where. And with what other wires. PLEASE HELP!
  • I'm not sure as I don't have the same model. Did you check on suburban Website for a schematic? I'm thinking everything you need to know you should find there.
    Btw, you will get more answers if you move this post to the correct forum topic. This is for forum issues.
