Chris_Bryant
Sep 18, 2014Explorer II
KJINTF wrote:
Chris
"That" much as in 1/2 reduction? I hope so but am not holding my breath
The motor is rated at 6.5amps - Data from the Suburban web site
My 2025RV reads it taking 7 or 8 amps to do the job
Agreed its moving combustion air as well as room air
For me it's worth a few $$ to take a chance
Sure hope the manufacturer comes through with a nice motor
My Fan-Tastic fan motors are way more efficient that the cheap motors in the Suburban furnaces
Ken
I hope to - but am not setting my expectations too high - even a two amp current reduction would be nice and well worth the effort
The whole furnace is rated at 6.5 amps, but fully 1 amp of that is electronics and gas valve. The fact that yours is drawing above that does mean your motor is failing. The issue is amount of air moved- you can lower the current draw by blocking off some of the air flow, but that really isn't a good idea.
I'm sure you can lower the current draw, but I think only in the 10-15% range, or a half to one amp.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
