- wasatchmtnatvrExplorerCircuit board. Dinosaur fan 50 plus is a quality replacement board. A sail switch stuck is extremely rare, but may happen.
- n7bsnExplorer
John&Joey wrote:
Chris is pretty much dead bang on, on his guesses. Sail switches do go bad and/or attract lint/dog hair/etc... stopping them from working.
Chris is also a pro, even owns his own RV repair business - John_JoeyExplorer
Chris Bryant wrote:
A newer model will not start the blower if the sail switch is stuck closed.
Chris is pretty much dead bang on, on his guesses. Sail switches do go bad and/or attract lint/dog hair/etc... stopping them from working. - n7bsnExplorerDoes it "click" if you turn the thermostat off, wait, then back on.
If so, the click means the thermostat is probably working, if not, it might be bad.
If it does click, see the advise above - wildman55_98ExplorerSuburban SF-30F Furnace Duo-therm thermostat No blower just click when it went off.
- n7bsnExplorer
wildman55_98 wrote:
Ok my furnace on our 2008 Keystone Cougar 276 came on this morning started to heat up and then shut off after about 15 mins.andnow does not want to come back on.
Any ideas on what it is. Blower, control board or what?
Who knows.... furnace model, thermostat model, exact symptoms, much more details needed. - wildman55_98ExplorerOk my furnace on our 2008 Keystone Cougar 276 came on this morning started to heat up and then shut off after about 15 mins.andnow does not want to come back on.
Any ideas on what it is. Blower, control board or what? - wildman55_98ExplorerThank to all. Got it going again.
- Chris_BryantExplorer IIA newer model will not start the blower if the sail switch is stuck closed.
- Old-BiscuitExplorer IIIDon't know what year RV you have so........
Power comes from t-stat to either a stand alone 'time delay relay' OR a 'blower power' (time delay incorporated onto circuit board).
Power then goes to fan motor.......
Fan motor power is from DC Dist Panel FUSE and goes thru a switch/cb on furnace
Check for blown fuse on DC Dist Panel
Check for tripped switch/cb on furnace
If BOTH OK.........blower power module on circuit board bad. New circuit board
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 27, 2025
