NorthwestBound's avatar
Oct 04, 2017
Suburban SF30 furnace problem
Kinda need some direction here.... My furnace operated fine all last winter but started to act up nearing warmer temps. Since the temps are getting lower here in the PNW, i have been trying to get the furnace back up and running.
When it worked properly, you would turn it on, the thermostat would call for heat, the blower would start about 10 seconds later, then about 20 seconds later you would hear a "pop" sound and then the slight jet engine sound of the burner working. As winter went on, the jet engine sound got fainter and the pop turned to a click. It also seemed to not be as warm as it had been before.
Then, it got to the point where you would hear the click, feel some heat, then, 2 minutes later, it would just blow cold air.
Now, the blower starts after the delay, no click...pop...whoosh or anything else. Just blows cold air as long as the thermostat is set to heat.
Heres what i know:
I have 13v to the furnace and a good ground
I have a good signal from the thermostat
I have good airflow and fan speed
Sail switch is operating and works as designed
Propane supply is getting to furnace
Delay switch is operating properly
Thats as far as ive been able to go so far. Anybody have an idea of what could be happening? It seems like its just been progressively heading towards failure. Thanks in advance!
  • Yeah, a bit high but most shops are closed on saturdays, dont have time to get to the shop on weekdays. Just glad its working now.
  • rhagfo's avatar
    rhagfo
    Explorer III
    NorthwestBound wrote:
    Well, i found an rv shop to bench test it. $225 later, it has a new Dinosaur card in it. $100 for the bench test, $125 for the card and install. Now to reinstall it.
    Ouch! $100 for a bench test?
    I had a place test mine, no issue found no charge!
    That said after that test and still issues once back in the RV I replaced the propane regulator and issue solved.
    Happy you found the issue!
  • Well, i found an rv shop to bench test it. $225 later, it has a new Dinosaur card in it. $100 for the bench test, $125 for the card and install. Now to reinstall it.
  • My bets on a clogged orifice. Very similar problem that I experienced.I used some carburetor cleaner to blow mine out.
  • I plan to check all that saturday, ill start pulling ducting and wires friday night, then pull it saturday morning while the rv parts houses are still open.
  • Clean burner and gas orifice
    Clean spark electrode and check that wire connection is clean/tight
    Clean circuit board edge connector.....pull connector off/check that pins are not bent----clean edge contact using pencil eraser....push connector back on making sure you have tight contact
    Spark electrode gap S/B 1/8" and centered over burner slots so it is engulfed in flame when it lights off (flame proofing signal goes back to circuit board via spark electrode)
