RAINEYTXX's avatar
RAINEYTXX
Suburban SF30q quit during the night
Full timers and our primary furnace quit overnight-fan will not run. Power to furnace, can hear click on control board when turning on but no fan. Power from thermostat into blue wires for heater but no fan.
Control board? Does the furnace slide easily out of it's sleeve or is there ductwork to disconnect?
Cold weather coming and want to get running asap. The control is in the rear of the enclosure so gas line and electrical connections have to be disconnected. Is there power and ground and blue thermostat wire only? Gas connection easy to connect/reconnect with no leaks. Plumbed with solid copper line but has 90 degree elbow at furnace with threaded connection.
Thoughts or suggestions of other things to check.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
