MFL wrote:
I'm thinking my 6 gal has two resets, one elec, one gas, under the black covers, behind burner tube. The 10 gal likely same set up. Igniter should click, even though it fails to light.
Jerry
If high temp t-stat has tripped....NO DC to circuit board so nothing would have power (gas valve/spark electrode)
120VAC is LEFT side (electric) Black wires
12VDC is RIGHT side (propane) Red wires
High temp t-stat...manual reset (Push to Reset on cover above gas valve
High t-stat to normal t-stat are connected via a wire...wire sometimes burns into. Remove Push to Reset Cover to check
Circuit board.could be burnt circuit...remove circuit board and check backside for scorched marks etc (backside of water heater tank..glued on)
