Old-Biscuit
Jun 11, 2019Explorer III
prstlk wrote:
Thanks to all who answered. It was indeed the check valve at the top of the water heater. $10.00 part.
I would recommend everyone have a 1" deep well socket on hand in case you need to remove the old one.
Make sure that you open the pressure relief valve on the water heater so it can fill with water after the replacement.
Also recommend that you study up on being a contortionist because you have to crawl up into the belly of the unit to be able to get to the check valve (at least that's what I had to do).
Glad you got it working!
No need to open T&P Relief Valve when refilling.
Turn on water supply and then open nearest faucet hotside.
This will allow cold water to flow into WH Tank, displace the air in system AND establish the 'air pocket' at top of tank,
Air pocket helps control pressure increases when heating water as it will SWELL when heated so w/o air pocket pressure can increase and cause the T&P Relief Valve to 'weep'
Opening T&P can cause air pocket to be expelled vs being established
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
