Old-Biscuit
Jun 12, 2019Explorer III
Bobbo wrote:Old-Biscuit wrote:
Opening T&P can cause air pocket to be expelled vs being established
If you depressurize the water system and open the pressure relief valve, it will also re-establish the air pocket.
YES.........
That is How you can re-establish a lost air pocket
Opening T&P with NO pressure/flow
Opening it WITH water turned on can displace the air pocket because the water will churn inside the WH Tank and carry the air out thru T&P vs flowing naturally thru hot out dip tube to an open faucet
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
