TARDIS_TIME_TRA
Feb 28, 2015Explorer
HOT WATER HEATER PROBLEMS
We had similar problems. You might want to try cleaning out the gas supply lines to the heater unit (circled in red on part breakdown sheet.
Step 1... Turn off gas.
Step 2... Disconnect supply line
Step 3... Use a high pressure air hose to blow out the inside of all the piping to clean out minute partials that may be trapped inside
Step 4... Re-install the piping
Step 5... Turn on the propane
Step 6... Turn on the hot water switch to start the heater.
This worked for us on our way to Alaska in 2013. I was instructed on what to do by the host at one of the many campgrounds we stayed at...Hope this helps you.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
