Old-Biscuit
Dec 26, 2014Explorer III
Testing for and finding 120V AC at element means AC circuit is good.....from CB to On/OFF switch to set of t-stats to element.
Test for resistance....across the two terminals there should be continuity and then check each terminal to the body there should not be continiuity (a short to ground).
If you have high resistance then element is bad
That is one nice feature with Suburban....independent heating functions
Atwood combined functions 10 yrs. ago. Same circuit board and same set of t-stats
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
