kmb1966's avatar
kmb1966
suburban water heater relief valve - dripping
When turning on the water heater, (electric or propane mode) water starts dripping from the relief valve after the water heats up. I fiddled with the relief valve, letting some water spray out of the valve, but it continues to drip fairly constant. I pushed on the pin some and it will quit dripping, but when I let go, it drips nearly a steady stream. Is this usually just a bad valve needing to be replaced?
