Jonesz
Aug 16, 2013Explorer
So I did a resistance test on the two coils with my multi meter. The inboard coil ie. closest to the tank is bad. The other coil showed the proper reading approx. 40 Ohms. This is a very simple test and does not require 12V power being fed to the water heater. I have ordered the White Rogers coil from PPL.
RedRollingRoadblock have you got any pointers on installing the new coil when it gets here. Looks to me like the screws are a non-tamper type holding the coils to the gas valve?
Any help appreciated
Jonesz
Jonesz
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
