Jonesz's avatar
Jonesz
Suburban Water Heater won't light
Have done all kinds of searches but am still confused. I have a Suburban SW6DE heater that will not light on propane. It was fine when stored a year ago but now does not work at all other than on shorepower after replacing the electric element which was fried. We have not used the heater on 110 V since buying the unit used 3 years ago. And I am assuming the element has always been toast. So the question I have is: How do I determine whether the problem lies with the control panel or gas valve. I don't want to order a replacement only to find I got the wrong thing. This is what happens: When I turn the heater switch on it tries to light for the 3 programmed attempts and then locks out. There is spark at the igniter but I can detect no propane odour at all. The tube from the valve to the heater seems OK and I did use a small diameter brass wire to poke into the gas oriface. I have recycled the off on switch several times in a row to make sure that the line would be charged with propane. The stove and furnace both light.Lots of propane. I used a mutimeter and checked all four connections to the valve while trying to fire the unit. There is activity at all connectors but I cannot give definite values as the readings fluctuate so widely. Any and all advice appreciated. The nearest dealer is quite a piece away. I phoned them but they do not stock the valve and would have to order one for me. Thanx
  • FYI - Most of the time when I find a bad solenoid on the Suburban Gas Valves it is because the Drip catch under the TP Valve is bent downward away from the Burner. This causes the drips to run right onto the Solenoids and eventually burns them out. Many times it causes intermittent performance as the Solenoid gets wet and quits working until it dries out.
    The tray is designed to be bent upward directing the water away from the gas valve. Check yours and see if it needs a bend so you don't burn out your new Solenoid.
  • Thanx for the heads up Forumcoach. Gave it a small tweak and it should be good to go.
    Jonesz
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
