theoldwizard1
Jul 10, 2018Explorer II
I had a similar problem on a Dometic Water Heater. 3 trips to the dealer could not solve the problem. I would say this was about a 90% cure. Remove both thermostatic switches. Clean the face of the switches with a Scotch Bright pad as well as the face of the tank where they touch the tank. It you want to get fancy, apply a bit of thermal heat compound they use CPU cooler (NOT the adhesive type !)
For some reason the gas valve were just not opening up !
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
