old_guy's avatar
old_guy
suburban water heater
I have a ten gallon water heater and the wire that controls the gas needs to be wiggled if I want the gas to come on. the wire connector is behind the black reset cover on the face of the heater.I am having one of those senior moments and am trying to remember what to do to make better contact. tried sand paper, tried to squeeze the fitting tighter, any other trick I can apply to make this thing work when I throw the switch inside the TT
  • Some of the issues with Suburban t-stats
    1) Crimps on connectors
    2) Wires getting chaffed due to rubbing against edge where metal is folded over
    3) Connecting wire between t-stats
    4) Loose/dirty contact between t-stat and tank wall
  • If there is a crimped on connector on the end of the wire there may be a bad crimp, maybe crimped on the insulation too much and barely making contact with the wire. Also possible the wire has a break inside the insulation some where
    An electrical contact cleaner may help. Just had a problem with my ZTR not starting. Pulled some connectors, sprayed with elec cleaner, solved the problem.
    Are you sure it is a bad contact or a worn out thermostat? I have replaced both the 120v and the propane thermostat on my Suburban twice each over the past 5+ years full time.
