wa8yxm
May 03, 2020Explorer III
I would visually inspect as much of the line from the main distribution manufold to the burners as I could. IF the other propane powered stuff is happy. most of the suggestions I have go poof
You have propane (NOTE Overfill won't bother it)
The REgulator is working
If you have a solnoid valve controlled by a gas detector it's open
Main tank valve is open
Since you have 3 burners (most stoves) the odds of all THREE valves failing at once approach snowball in a blast furnace (Though I was going elsewhere didn't you.. Same heat). That leaves the orifices (Gas jets) spider webbed or a pinched gas line.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
