Matt_Colie
May 04, 2020Explorer II
When you get through with the above, lift the cook top and see if there is either a valve or a regulator under there.
If there is a valve, check that it is open and clear.
If it is a regulator, check with the manufacturer to find what the burner pressure is supposed to be and how they advise that you check it.
Matt
Matt
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
