rk911
Jul 09, 2017Explorer
pbitschura wrote:
My older "C" has no low point drain. For years I drained it by pumping the water with the grey valve open. Lately, I decided to pump it by leaving the water heater plug out. I got to wondering if there might be a easy mod that would drain the tank directly. I'm a little adverse to drilling holes in it as it is an older tank. I'm not sure about connecting a hose to the pump directly. Maybe a T and drain valve. Ideas please.
had the same problem on our '85 Winnebago Chieftain. never could find the low point drain despite Winny's claim that there was one. I did the same as you...pumped it through to the gray tank. a PITA but it worked.
