bshpilot
Sep 24, 2014Explorer
2oldman wrote:bshpilot wrote:The link you provided shows an inverter/charger. I looked up the unit you mentioned and found it is only an inverter with a xfer switch.
I even followed up w/ information and posted links so that people would learn
It's likely you can turn off the charger on ALL IC's.
depends on which comment / links you look at (that i provided).
After reading the manuals (on-line) yesterday i discovered that the charger in the ProSine 2.0 can be disabled with the included remote and it also includes a built in transfer switch for pass-thru.
The Pro XM also includes a built in transfer switch for pass thru and it does not have a charger.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
