BFL13
May 17, 2021Explorer II
The screen door pops open easily, so with the plexiglass over the bottom half of the door (so you can still see out of it) also put a sliding bolt inside just below the opening where you get at the main door handle.
From outside you can reach in and undo the sliding bolt. But be careful not to close the main door while that bolt is across or now you can't get in! ( You can but you have to overcome the way the door and screen door hold together)
