Pipeman
Jan 10, 2014Explorer
I poured bleach into the heater via the drain plug. I poured it in until it started to drain out. Put the anode rod back in, filled it with water, ran it through the system and let it sit for a day or so. I then drained it and flushed the whole system with clean water. When I dewinterize I will do it again to be on the safe side and install a new anode rod. Hopefully that will solve the problem.
