msiminoff
Jan 10, 2014Explorer II
As others have mentioned, the sulphur smell is a result of the anode rod. Anaerobic bacteria in the tank reacts with the aluminum and/or magnesium from the anode and creates hydrogen sulfide gas (that's the sulphur smell).
I suggest that you drain the water heater, replace the anode with "combo anode" that is made from aluminum & zinc. Then add a bottle of hydrogen peroxide (just as effective and much safer than chlorine bleach) to the heater tank, fill with water, and allow it to sit for a few hours. Then flush another two times with fresh water and your you'll be odor free.
Cheers,
-Mark
Cheers,
-Mark
