Old-Biscuit
Jan 10, 2014Explorer III
kevden wrote:
I did not know there were different types of anode rods, ours is due for replacement, I will look into the zinc. Ours gets stinky if left for a few weeks without use, but leaving a faucet open for 5 minutes has been enough to flush it out.
Pros/cons for the two types of RV anode Rods available
Magnesium anodes produce a stronger current making them more effective at keeping the water tank from corroding.
Magnesium may react with bacteria causing a sulfurous smell.
Aluminum rods don’t have this problem as often.
Aluminum rods collect a buildup of corrosive materials that harden and make taking them out for inspection or replacement a challenge.
These are the 2 types available for Suburban RV water heaters.
No need to replace an anode rod until 75% of rod has deteriorated. That's what they are suppose to do.
