dougrainer
May 25, 2016Nomad
Tachdriver wrote:
Isn't there a temperature adjustment in the refrigerator? My domestic has a sensor that you move on the cooling fins inside.
There are 2 models of Dometic. YOU have the Auto temp and that is the one you slide the inside Thermister mount up and down on the fin. THAT only changes the preset by no more than 4 degrees up or down. The OP from what he stated has a Manual adjust thermistor and has 1-5, 1 being the warmest. IF the refer will freeze, you check and make sure the Thermister is indeed installed on the right hand Evaporator fins. If it is hanging down it will run the refer full cool and freeze. IF the Thermister is installed correctly, and it freezes, the Thermister is defective and needs replaced. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
