jrp
May 25, 2016Explorer
The H2S smell comes from bacteria in the water source, or the water lines or the water tanks. This is common when filled from a well supply, since its not normally chlorinated like city water.
You need to disinfect the entire system, including the hot water tank and each branch & fixture. Just draining & refilling does not get rid of the bacteria. It will get worse until you disinfect with diluted bleach or chlorine.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
