beemerphile1
May 25, 2016Explorer
dougrainer wrote:beemerphile1 wrote:sharmendinger wrote:
Have had a Sunseeker 3 years and never had this problem until this spring. The water has a slight sulfur odor. I have drained the whole system and refilled, but problem still present. I fill from our well (filtered) and don't have this problem in our house.
Also the frig is freezing food. I have set the temp control to the lowest setting to no avail. This just started this spring also!
Any help/information will be greatly appreciated!
Steve
Adjust to a higher setting, not lower.
NORCOLD AND DOMETIC. Dometic 1-5 FIVE is the coldest setting. Norcold 1-9 NINE is the coldest setting. Doug
That may be true, but when saying your refrigerator is too cold, you need a higher (warmer) setting, not a lower (colder) setting.
O degrees is lower (colder) than 32 degrees.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
