Old-Biscuit
May 25, 2016Explorer III
beemerphile1 wrote:dougrainer wrote:beemerphile1 wrote:sharmendinger wrote:
Have had a Sunseeker 3 years and never had this problem until this spring. The water has a slight sulfur odor. I have drained the whole system and refilled, but problem still present. I fill from our well (filtered) and don't have this problem in our house.
Also the frig is freezing food. I have set the temp control to the lowest setting to no avail. This just started this spring also!
Any help/information will be greatly appreciated!
Steve
Adjust to a higher setting, not lower.
NORCOLD AND DOMETIC. Dometic 1-5 FIVE is the coldest setting. Norcold 1-9 NINE is the coldest setting. Doug
That may be true, but when saying your refrigerator is too cold, you need a higher (warmer) setting, not a lower (colder) setting.
O degrees is lower (colder) than 32 degrees.
True if discussing 'degrees of temperature'
OP stated .......lowest setting (which would be 1 and that is warmest setting)
OP...look inside your food section----see the probe attached to fin?
IF not attached to fin fridge is running continuously freezing food section.....reinstall probe in clip on fin (Thermistor)
If Dometic....far right fin
If Norcold....10th fin from right
Sulfur smell....
Could be from water heater......drain/flush and treat with chlorine (replace anode if Suburban Brand)
Also check that your trailer battery is not source of sulfur smell.
Overcharging/boiling over------low water level---converter charging too much.
Batteries under those conditions will smell like sulfur also.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
