sharmendinger's avatar
May 25, 2016
sulfur smelling water and frig is freezing food
Have had a Sunseeker 3 years and never had this problem until this spring. The water has a slight sulfur odor. I have drained the whole system and refilled, but problem still present. I fill from our well (filtered) and don't have this problem in our house.
Also the frig is freezing food. I have set the temp control to the lowest setting to no avail. This just started this spring also!
Any help/information will be greatly appreciated!
Steve
    Steve
    Adjust to a higher setting, not lower.
  • donn0128 wrote:
    .....freezing food? What brand refer? Likely a clogged coolant line. You could try taking the refer out and laying in different positions hoping to dislodge the blockage. How many times have you left it running when not level?
    A clogged coolant line would do the opposite, no cooling.
  • Sulfer smell is probably coming from the water heater. Unless you have an Atwood water heater change the anode rod.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
