the only thing I can suggest is trying hydrogen peroxide before the vinegar for an over night soak to kill off the existing bacteria more efficiently.
the other issue is what are you using for water to fill the rv? it takes bacteria to react with the magnesium or aluminum to make the Hydrogen sulfide gas, so if you eliminate the bacteria from getting in there then you eliminate the smell.
I don't understand the hydrogen peroxide/vinegar process you suggested. Would I fill the water heater with a hydrogen peroxide solution, let it soak, drain it, and then fill with vinegar?
Regarding the source of water - 10 or so different RV park water systems over the last 2 months.
- StirCrazyJul 23, 2025Moderator
ya the hydrogen peroxide will kill off the bacteria, plus loosen any organic material, the vinegar will loosen mineral based deposits.
this is a common treatment I see on boards and internet searches, I don't have to do it myself as nothing but city water (treated water) goes in my tanks
