After three trips to the local very well stocked hardware store, I came up with this: I ran a tap from the RV propane block to the front of the RV, which is regulated. I removed the Baby Q regulator, and adapted the remove regulator so that it can be reattached and a 1 pound bottle can be used. From the RV propane tap, I can run the Baby Q and the Camp Chief burner. I can also run the Baby Q and the Camp Chief burner from a large propane tank, as this weekend we are going on a camping trip with others and will most likely place all the cooking devices in a central place away from our RV.
From all the input I was able to make the above possible.
Thanks
Johnnie
