Well, here is an update to the propane conections. I wanted to beable to put the baby Q out from the awning, so I had about 15 feed of hose from the quick disconect to the baby Q, with out the baby Q regulator, as the port on the RV came from the RV regulator. Not sure if the hose length caused the porblem, but the flame from the baby Q was so low it was not usable. Did some temporary replumbing and got the baby Q running properly. The baby Q was not double regulatored.
So today, as we are going camping again, it the weather hold up, I replumbed the quick disconect from the RV stright to one of the porpane bottles on the RV. Tested the baby Q, and it works as it should.
Not sure why it did not work properly from the RV regulator, but it did not. it does work porperly with high preasure form the RV porpane tank to the requlator of the baby Q.
Thanks again for all the input.
Johnnie
