brisath's avatar
brisath
Surburban Furnace Not Igniting
Some other threads have helped answer some questions (here, here, and here), but here is where I am at with the furnace on my 1996 Winnebago Vectra:
1. Turn thermostat up past room temperature
2. Blower comes on and seems to run good
3. Light on switchboard never comes on.
4. No noise of an attempt to light or fire furnace
5. Only cool air blows through vents
Other info
-2 new batteries
-doesn't work under shore plugin or idling under motor
-I've also gone through the instruction manual steps for getting it to fire, which includes 5 minutes with propane turned off, then turn propane on and repeat.
-Propane is at 2/3 level
-The switch on the furnace itself is ON
-5 amp fuse on the circuit board looks good
-water heater pilot works just fine and comes on regularly. Refrigerator works when unplugged, stove burners work fine.
If it is a sail switch, how do I check that?
As a first step, would it be good to fill the propane tank completely?
Here is a picture of the furnace:
and circuit board
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
