- RLS7201Explorer IIYes I use the type of fuse you ask about.
I think the're great. No additional wiring.
Just bolt it to your deep cycle battery, hook the cable to it and you're done.
Richard Bigfoot2005 wrote:
YesJiminDenver wrote:
Terminal block holders also come in doubles or you can use this fuse block bus bar.
Blue Sea Systems MRBF Surface and Terminal Mount Fuse Blocks
Yes, I know that. But my question is can I use this type of fuse (Single fuse style) instead of the traditional T class or ANL fuse?- Bigfoot2005Explorer
Yes, I know that. But my question is can I use this type of fuse (Single fuse style) instead of the traditional T class or ANL fuse? - JiminDenverExplorer IITerminal block holders also come in doubles or you can use this fuse block bus bar.
Blue Sea Systems MRBF Surface and Terminal Mount Fuse Blocks - Bigfoot2005Explorer
RoyB wrote:
I like anything made by BLUE SEA...
I don't like to put more than two ring terminals on a stud bolt... If you are planning on having several rig terminal connections then a Blue sea Terminal Strip would be the thing to use as well so that no more than two ring terminals are used on one stud connection...
Google image
Roy Ken
No, I would only use 1 fuse for just my inverter. I am just wondering if this type would work instead of using a ANL or T class fuse. - RoyBExplorer IIII like anything made by BLUE SEA...
Google image
Roy Ken
- Some B+ vans and Tiffin motorhomes uses those 300 amp types for the Inverter AND heavy amp charge circuits. Doug
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
