valhalla360
Aug 17, 2020Navigator
Do you not keep insurance on the RV because you haven't had an accident in the last 20yrs?
Same principal. Now how fancy of a unit, that can be open to debate.
Personally, I would be nervous with a 30amp rig that tries to run 2 air/con units. Continuous draw allowed per code on a 30amp outlet is only 24amp. Your average rooftop air/con pulls 10-15amps, so 2 will be 20-30amps and the lower the voltage, the higher the amps. Hopefully the system has it built in but I would be checking the amperage draw the first few times, both air/con kick on.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
