Executive45
Mar 10, 2015Explorer III
Most likely cause is there is no ground wire connection...:W
Probably the receptacle is wired incorrectly and/or incomplete. Pretty easy to do if you're not an electrician. You don't say whether your receptacle is 30 or 50 AMP service. 50AMP has two hots, a neutral and a ground.
To easily check, use a meter and probe one of the hots and connect the other to the ground. You should show 120V on each leg. If not your ground wire is missing/broken/cut or was never installed.
To better help us help you, provide the NEMA number on the receptacle.....Dennis
HERE is more info...D
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
