westend
Mar 10, 2015Explorer
If you can find a receptacle that has a known good ground, you could use an extension cord and see if there is continuity between the ground in the receptacle you're getting the fault on and the path to ground in the extension cord.
If continuity is observed, the surge guard device would then be suspect.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
