Hiking_Hunter
Mar 11, 2015Explorer
smpsmpsmp-
All the above advice is good, but before you go to a lot of trouble, try a quick test: Turn the breaker off, then scrub the plug in and out of the receptacle a few times. Sometimes the contacts (in this case the ground contact) in the receptacle get corroded and lose connection. That can happen with temperature changes. Then see if the code on you surge suppressor clears. If you have any adapter in the line, scrub those contacts also.
This is just a troubleshooting test - if it clears the problem you probably need to replace the receptacle for a permanent fix. Use a good quality receptacle.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
