mshiningstar's avatar
mshiningstar
surge protector newbie
I realize that this is a very basic electrical question but I am just a bit confused. I read that you can take a 30amp surge protector with a 50amp adapter and plug it into a 50amp pedistal plug to run a 30amp camper with no problem. I need to know what is best to use if I am plugging a regular 15 or 20 volt cord into the plug of the the pedistal to run to an outdoor TV/Blu-ray DVD player, what should I use for a surge protector? I want to be sure that the electronics are protected from low/high voltage. I am looking at a Progressive Industries 30amp EMS protector for the camper but what about this cord that I want to run directly instead of running through the camper's power? Can anyone offer suggestions or explain what will work?
  • If you are talking about just plugging into the 15amp plug on the pedestal. Then you should be able to get a regular surge protector like you would run at home. I would look for one that is rated for outside use.
    Just curious, why would you not use the 15 amp plug on your unit?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
