- AllegroDNomadA surge protector will not. A Surge Guard Power Protector and better yet a Progressives Industries Power Protector will. So it depends on what you are calling a surge protector.
A volt meter reads volts/amps/ohms/watts, depending on which one you get and can be 120 and/or 12 volt. - joe0508Explorer
WILDEBILL wrote:
Thanks,I know it wont help.I am trying to figure out if a surge protctor will indicate a low or high voltage to protect my air conditioner the same as a plug in voltage monitor.
Neither will help with low voltage you need an autoformer to boost low voltage.
A surge protector will help with over voltage (surge).All A voltmeter will show you the voltage.
Bill - WILDEBILLExplorerNeither will help with low voltage you need an autoformer to boost low voltage.
Bill - 2oldmanExplorer II
joe0508 wrote:
I don't think the two are similar in any way.
Will a surge protector help with low voltage like a plug in voltmeter? - CA_TravelerExplorer IIIA true surge protector protects against transient voltage spikes. A power protector detects high/low voltage, etc. and disconnects. A autoformer boots low voltage.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
