Reading a post on choosing between TPMS and surge protector. I only monitor my duals with a cheap TPMS and quite happy with it. Have not looked into this but thinking why cant I add a whole hous...
There is an issue when using a Generator! You will need a special wired adapter to use with a generator! Make sure you do not get an Open Ground indication, you will need a floating ground plug. You should be looking at an EMS (Electrical Management System) which does a lot more than simple Surge protector. Yes, they are more expensive, but the value if your electrical system/components is very high.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
