Lspangler
Jan 22, 2018Explorer
Surge protectors
I have a TT with a 50 amp cord. However I only have one AC. Do I buy a 30 amp surge protector or a 50 amp? I have no plans to add a second AC Thanks Linc
SoundGuy wrote:SoundGuy, your suggestion, as-is, is a safety and fire hazard.Lspangler wrote:
Everything in my trailer works on a 30 amp pedastel.otrfun wrote:
You cannot hardwire a 30 amp surge protector or EMS in a TT with 50 amp service.
Well that's not technically correct. When one uses a 30 amp male > 50 amp female dogbone to plug a rig wired with 50 amp service into a campsite 30 amp source that dogbone applies the 30 amp's single hot line to both hot lines of the 50 amp service. This being the case there's no reason one couldn't also hard wire a 30 amp EMS into a rig with 50 amp service in the same manner. That said, if the OP's rig truly is wired with 50 amp service then I'd agree - ante up for a 50 amp EMS, whether portable or hard wire, and properly protect both phases of the trailer's 50 amp service. Unfortunately the OP hasn't clearly explained exactly how he manages to use a 30 amp main service cable with his 50 amp rig - pics would be helpful so we know precisely where the 50 amp > 30 amp conversion is occurring.
