Lspangler
Jan 22, 2018Explorer
Surge protectors
I have a TT with a 50 amp cord. However I only have one AC. Do I buy a 30 amp surge protector or a 50 amp? I have no plans to add a second AC Thanks Linc
SoundGuy wrote:No one said you were confused, but I do believe you're failing to take full responsibility for your post.
Nonsense ... I'm not "suggesting" anything, I merely pointed out that the statement one "cannot hard wire a 30 amp protector in a TT with 50 amp service" is TECHNICALLY incorrect. How this rig may be used subsequently, whether another A/C may be added later is another issue, just as it would if a portable 30 amp EMS was being used and the owner wanted to run dual A/Cs. Regardless, the point is moot as the OP has already said he's chosen to install a 50 amp hard wire EMS. NO confusion here whatsoever.
