Bamaboy7467's avatar
Bamaboy7467
Swap Norcold N821F
Hi,
I'm in the process of possibly having to replace my N821F and can't find the dimensions of the unit to make sure I find a proper unit that will fit in the cavity, just incase I have to replace it. Anyone know where I can find that out? Or a good one way replacement fridge that will fit and not cost over $1000?
Thanks
  • A few years back I had to make a decision as to what to do with my norcold (different model) as it stopped working all together. I found there was a few residential all electric frigs. that would work, but would require more wood working skills to make it look great than I had. I did leave that option open as I looked at new norcolds that would replace the old. For some reason everything I read said that to put a new one in I would have to go through the front windshield (ClassA) and that was not an option at all.
    I then found JC Refrigeration. What a great company I decided to replace the cooling part of the frig. This was a great DIY project with better than great customer service from JC.  If you are not a DIYer and am close to Shipshewana, IN stop in to there shop.
    Home - JC Refrigeration (jc-refrigeration.com)
  • Did a search on Norcold N821F install manual. All the required measurements are in there.
    Manual
