wolfe10
Aug 23, 2018Explorer
Advantage is less voltage drop (larger gauge wire and 50 amp CG outlets often have larger gauge wire feeding them.
You can certainly make a 30 male to "50 amp RV inlet" adapter to use when voltage is OK.
And, your RV may have a standard inlet in which case you may be able to find a pre-made adapter.
You could also leave the 50 amp cord coiled up and use an off the shelf 30 male to 50 female adapter.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
