DrewE
Aug 23, 2018Explorer III
Is this a detachable cord? If so, you can keep it and just get a 30A cord that connects to the existing 50A connector, reserving the 50A cordset for times when you find it needed. If it's a permanently attached cord, I'd suggest leaving a short 50A cord and turning the rest of the existing cord into a sort of 50A extension cord, and then having a 50A socket on your 30A cord so you can go back and forth if needed.
If you have an electric water heater, you could not use it and the air conditioner and much else (such as the microwave) simultaneously on 30A power. Obviously in cold weather the air conditioner would not be required.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
