DrewE
Aug 23, 2018Explorer III
Boomerweps wrote:
Check your TT circuit breaker box. Since 50 amp service is really TWO 50 amp legs, you likely have items split between the two and might not have some items supplied with power via one leg of 30 amp UNLESS your 30 to 50 amp adapter has an internal splitter to both hot leg contacts.
Every RV 30A male to 50A female adapter connects both legs of the 50A service to the 30A hot. The fact that there are two separate legs is entirely a non-issue when using an adapter unless you have some 240V appliances in the RV--which is quite rare indeed. Of course, the total power available on a 30A circuit is considerably less.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
